Hi, I have a leak coming from the area of the water pump on my clio, i was wondering if it is the water pump i need a new water pump or can the seals be replaced. And i also wanted to see if any one has done the water pump before.:confused:
The water pump is a common place for coolant to leak,it will need to be replaced.
Depending on engine type (which you don't mention) the cambelt may very well need to be replaced at the same time as the belt runs the pump.
