1 - 1 of 1 Posts
Hey all! My Renault Clio 2012 is impossible tu drive in warm condition..When the engine is cold it works perfectly att all speeds end upp to 6000 rpm without the slightest problem .When the engine gets hot then it is not possible to accelerate at all, and shake violently when doing so. Lose power altogether and you have to sneak with the accelerator to get up to 70-90 km. This only under load. With the car standing you can get up to 6000 rpm without any problems. Så what happened is that you can´t drive the car at all when it´s hot .Code 0P300. I have replaced cables, ignition coil, plugs, and i have gone through all the vacuum hoses without succés. Any ideas?
1 - 1 of 1 Posts
