Hi there,is there anything I can put into my drivers side lock to dissolve the superglue some kind person decided to put in there, or will I have to replace the barrel,I have a 98 Clio s reg,thanks.
Acetone can disolve superglue.
Would be worth getting a cheap bottle of nail varnish remover and squirting some in the lock.
Leave it to work for a few mins, then wash out using WD40 or similar with a straw.
Repeat if needed.
i would think twice about acetone, my bf works for a beauty suppliers and acetone will melt plastic, it's used to take false nails off
thanks for the quick responses,I suppose if I mask up the area well I might get away with it,once again thanks for the quick replies.
Hi there, I hadn't noticed this thread when I replied to your other one on the same topic, but you might want to have a read.
Paul:)
Hi HubPhone - I suggest you contact a locksmith for advice they are called out to commercial premise with this problem al the time:)
