Please help i switched my car on today and the serv light came on and also and light with a person and a big circle in fron of them what does this mean surley it doesnt need servicing as i only got it in oct 2006 help please:mad:
what my clio manual says is that if the serv light and Airbag warning light (light with a person and a circle in front) or just the Airbag warning light comes on then there could be a fault with your airbag system and you should contact your renault dealer as soon as possible.
Hello & Welcome to the Forums Liz.
I would give your Service Department a visit ASAP to get this seen too.
Ottoman
Just had this on my clio, turned out to be a loose wire on the drivers seat airbag from the adjusting of the seat, turns out that this as a common problem, had to get renault to sort mine, as yours is 2006 it shold be covered by warranty
S
Yep - get it in. It's probably a simple one and if it isn't it's Renault's problem...
