Hi i would top it back up right know with the engine running and the bottle top off and keep adding water until you are sure it is filled,when the car is running and the bottle top is back on have a wee look around to see if there are any obvious leaks i hope this helps Donald
Yep as Donald says top it up now, Once you have established there are no leaks and the level stays stable, I would fill with the appropriate mix of coolant/antifreeze mixture as soon as possible as there is rust inhibitors in the mix.
Ottoman
