I have a Renault Clio 1 RT 1994 - have recently bought a new offside wing but can't work out exactly how to change it!
Have looked in the haynes manual & online for relevant information but still can't find any so will really appreciate anything you may know.
Cheers, dex
The wing is only bolted onto the car,although some of the bolts are well hidden.If you open the bonnet you'll see the top bolts,there are some hidden under the front bumper(which you'll have to remove to access the bolts).Also,remove the plastic wheelarch liner to access the rear bolts.
It's fairly straight foward,as long as all the bolts come undone.Obviously they've been in place for 13 years on your car,so a dose of WD40 or similar on them should make removing them a little easier.
thanks a lot for the welcome and the advice - I had a feeling I'd have to take the bumper off - that will be a nice weekend job then!
cheers, dex
