Hello,
I'm trying to fix a RENAULT CLIO II 1.4 (75CH) from 1998 running on petrol. The symptoms are as following:
1) Can't idle (sometimes can). If I don't hold the acceleration pedal, it just dies. I suspect a bad IAC valve, but I'm unsure how to test it.
2) Rough running. At (supposed) idle speeds (below 1000 RPM) the car is really shaky. Accelerating it (in neutral) makes the shakiness go away to some degree, and it runs better once it reaches 2000 RPM. I can still feel it shaking, but much less.
What I did so far:
I looked at the fuel trims and basically, it indicates a vacuum issue, however, it could be something else too. The LTFT is maxed out (probably) at 30, an the STFT kind of fluctuates, but goes down when I accelerate it. I could post the graphs if needed.
I cleaned the throttle body, MAP sensor, and the IAC valve. The IAT sensors were 4, but I didn't clean them yet, and I don't have with what to clean them for a while either. The EGR valve (or what it seems to be that) was not cleaned either, as it was a pain to take out. The air filter seems acceptable. It could be possible for a leak between the intake and the throttle body, but would that affect it very much?
I checked the coils, and their resistance seems consistent, besides the last one (let's call it number 4), which has a little bigger resistance, but the wire is also longer, so it maybe could add up to normal.
I pulled out the coils one by one and started the car. It seems that the coils 1,2,3 affect the run (probably), but 4 does nothing.
I then pulled the coil 4 out while the engine was running, and then it made absolutely no noticeable difference. The coil does seem to fire, as I heard it firing when I plugged it out.
I'm unsure what the issue is for those symptoms. I'm guessing cylinder compression / blown head gasket / intake or exhaust valve? Coil misfire? Bad spark plug (I did not test it yet)?
Can anyone point me in the right direction?
Thank you in advance
What I did so far:
