hi i need to remove the tweeters in my clio 2002 dci so i can replace them with better ones.
whats the best way to remove them. can't seem to get behind them for pull htem out from the front. will i need to remove the dashboard and how do i do that.
thanks for any help
phill.c
Alrite m8 yea im quite sure ur going to have to remove the dash. Your going to need a torx 20 screw driver thing. there are two screws on the side like above the fuse box on the passengers side and same on the other side. You will see silver strips on your dash if you take them off screws under there and underneath the steerin wheel casing theres 2 screws take them off and remove the casing and this should reavel more screws. Finally in the vent that is in the dash right near the winscreen there are screws there and you will hav to pull the plastic vents off and the dash board should slide out.
hope this helps i removed my dash to put a wire to sort the steering wheel stalk to aftermarket headunit.
