I have an p-reg 3-door Renault Clio 1.4 I could not get it started because the key plip will not work. Although I could get into the car by manually unlocking the driver's door, the engine would not start because of the immobiliser mechanism.
The problem seems to be that about a month ago water started entering the sensor unit in the roof either through the sunroof or the aerial mount which got the sensor wet i took it out and dryed it out it started to work if i held the key plip up close for a few seconds but now it has stopped all together.
is it possible to by-pass the the immobiliser mechanism and use the key manually
