Hi, Hope someone can help. My car has suddenly decided to stick in 3rd gear and wont change up at all. Can anyone tell me where the transmission fluid checker might be?
Renault Clio Mk 2 Transmission stuck in 3rd
Thanks for replying, Its a really weird problem because it stops in D 3rd gear, it lets me change by going in from 1 - 2 but then it doesn't change to top gear. Anyone got any ideas??
No there is no warning light on the dash.
Thanks Gail
Let's be carefull out there
Thats an odd one, normally low ATF level would throw a warning light on the dash. I thought maybe gear selector linkage needs adjusting but it does not sound like it.
I had a problem recently which sounded similar and I sprayed oil doen the gear selector cable, operated the gear stick several times and it was ok, might be worth a try.
