Hey!
So in this wonderful weather I decided to open the sunroof. Got it clicked into position, then hit a pothole and >snap< the lever/handle to keep the sunroof open cracked and it closed.
The sunroof still opens but closes after going over a bump, because it can't be left open.
Would any of you know if it would be possible to convert it from manual lever opening to an electric opening sunroof?
Thanks in advance!
I dont know if you can do a direct coversion of your present sunroof from electric to manual, someone may know a way, I think you might have to be looking at a complete sunroof replace from a Clio with a manual sun roof, you could always knock yourself up two wedges of 5mm plywood with a 10mm x 10mm cross member to keep them apart and to stop then flying off, open your sunroof and wedge it open with your newly patented "sunroof keep held open when broken device"
