Hello,
I have a Renault Clio 4 with the touch screen Headunit.
Automotive lighting Hood Light Grille Motor vehicle
The touchscreen has stopped working, and recently I disconnected the battery. Now the radio is asking for a code.
There's no way to input the code.
I want to change the headunit completely with a Pioneer one.
Vehicle Gear shift Car Satellite radio Motor vehicle
Something in this model.
I've searched the net for a Facia (the plastic frame surrounding the headunit, but cannot find any for a 6-7" headunit.
All that is available is for a single din headunit (connect2) and 10.1" Android headunit.
Does anyone know where can I have this type of facia?
Regards,
Shravan
6x7 is the basic size of a triple DIN unit.
But as you say, they seem to be unavailable.
Thought of a Double Din kit with a single DIN blanking plate or pocket underneath?
I am assuming that the Pioneer unit is a Double Din and that the existing is Triple?
You mentioned Connect2....have you spoken with them?
Discussion Starter · #3 ·
I have sent them a mail, they haven't responded yet.
Just called them, i'm from Mauritius GMT+4, they haven't started working yet :p
They have a special hour on Friday
I must admit I was wondering if your location was correct or result of a VPN.
It's 8.35 in UK at the moment...... they should open at 9.00 so give them half an hour or so.
