Hi Folks
I recently purchased the above vehicle and noticed that the air pipe that leads to the air filter had what appears to be a part missing which has left two largish holes for air to enter.
I will post a pic shortly and welcome any comments if this could cause any problems with the fuel to air ratio and if so should I just duct tape the holes up.
I'm suffering a los of power at the moment and have checked and cleaned the MAP sensor, all ignition coils appear to be fine. the power loss is so bad that I battle to getup my driveway in the mornings sometimes taking 4 attempts to get up the driveway. She idles fine in the morning but my driveway is quite steep so I rev her high but by the time I reach the gate, there is no power not even in first gear. The total kilo's is 145000.
On the highway she performs well but I have to use the gears frequently when there is a hill approaching. I have noticed that she is a little rough between 1000 RPM and 1750 RPM, thereafter as smooth as a babies bum.
For the record, I did add a bottle of injection cleaner to the tank thinking this could be the problem but as yet there has been no improvement. Perhaps over time this will improve though I'm not sure how effective this stuff is or if it's the cause of the problem.
I'm not sure what else to look for as a newbie to Renault but the loss of power is frustrating me to no end. Today I will check the air filter and see if it's clogged up or not.
All comments welcome please.
Please advise from the pic if I'm missing a part and what I should do about it.
Mack
Mack
