hi can anyone tell me what woucld cause the injection fault light to come on when turned on to the reds this is happening everytime the ignition is switched on with no fault codes peresent ..
what are the inaailt checks the ecu does even before the car is started
plz help
D
All i can think is the coolant temp sender, but don't know if that would bring up an injection fault.
TDC, cam sensor, lambda etc won't come into play until the engine is running / cranking.
