1 - 8 of 8 Posts
hi
i have a deisel turbo 1994 espace 2100cc.
when i press the accelorator dont laugh it sounds like a siren or a singing sound.
any ideas please...after you stop laughing
Hello & Welcome to the Forums.
I'm sure a Member will be able to assist with your post shortly.
Ottoman
Hi, it sounds like a belt or a bearing ... could be any of the following ...
turbo bearing, a/c compressor bearing, water pump bearing (although its usually a grumble)
any aux belt either too tight or starting to break up .... if its more a Zinging sound that varies with engine speed I'd have a look at the timing belt.
Hope it helps :)
singing renault
hi
as i press the accelerator it has a high pitch 'siren'sound then as i change gear it goes then starts again until i reach 5th gear then it justs light siren sound..the sound is the like driving at full speed with wind whistling if that helps.thanks for comments please bear with me
is your turbo boost gague working ?
could be the pipe has come off the manifold or has an ole in it ? could as stated be the bearings also check all the pipes from the turbo to the intercooler & from the intercooler to the inlet manifold for holes & leaks .does the boost still work or does it feel down on power could the waste gate be stuck open ? good luck !.
let us know what you find ok !
O
This is how my Espace IV sounded just before they had to replace the Turbo!
It could be one of a number of things but needs checking out sooner rather than later.
1 - 8 of 8 Posts
