Hi al, we have an renault espace 2.0l manual, W reg. We were driving today and heard like a grating noise/clunk that lasted for couple seconds then went, then it did it again and went, then all of sudden the car rolled to a stop, now we can start the engine, we can put it into gear but it will not move, we can select gears 1 to 5 without using the clutch, but to select reverse we do have to use the clutch, when it is in reverse when clutch released, we can hear a grating noise, when we press the clutch pedal down we can see the lever moving on engine under bonnet, i have removed the gear stck cover to check the cable their and gave a pull but it is stuck tight. We have been told it could be the gearbox (if can put in gear surely not) and also that it is the clutch (but need to use clutch to select reverse) is their anyone that has had this happen to them, any help is greatly appreciated, thanks for your time.
