2008 1.2 16v petrol
intermittent fault
turn the ignition key and there is nothing and the fan is running also the immobiliser light stays solid.
i have change the fuse box as it was wet and i thought that that was it, but no,took the ecu off and dried that out now its starts and runs great ,then if i leave it standing for about 30 minutes and go to start it then its back to normal nothing on the key.
i have change every fuse and relay and its still the same
could this be an ecu fault or maybe a broken wire as i read somewhere that there is a wire that goes from the ecu to the fuse bos .
any help would be extremely grateful ..thankyou.
intermittent fault
