My 2010 Renault grand scenic is much loved BUT the hand break has recently decided that it will not release when pulling away. The switch works, manually, ok for both lock and unlock but the unlock has stopped working in auto mode.
Any thoughts on which of the many sensors is likely to be the problem as I’m not sure that the, nearly due, MOT will pass!
On the clutch pedal.
Middle switch with the long lever....... often gets dislodged
