lots of blue smoke.uses a lot of oil.what is the problem?
S scottybhoy · Registered Joined Apr 15, 2011 · 2 Posts Discussion Starter • #1 • Apr 15, 2011 lots of blue smoke.uses a lot of oil.what is the problem?
R Recycled Scenic · Guest Joined Jan 1, 1970 · 0 Posts #2 • Apr 15, 2011 Hello and welcome to the forum What engine is it? Could well be worn or sticking piston rings especially if it's the 1.5 diesel engine.
S scottybhoy · Registered Joined Apr 15, 2011 · 2 Posts Discussion Starter • #3 • Apr 15, 2011 1.5 dci
R Recycled Scenic · Guest Joined Jan 1, 1970 · 0 Posts #4 • Apr 15, 2011 scottybhoy said: 1.5 dci Click to expand... Yes they are notorious for high oil consumption due to piston ring problems. IIRC I have read some where on the forum that you can use engine flush to clean the engine and free the piston rings off? Not sure that it will work?
