I have a kangoo 2010 plate. Only a slight problem but when I try to move the heat selector from cold to hot the dial springs back to cold meaning i cant get any heat out of it. Not much of a problem now but id like to sort it asap...
Thanks for looking guys.
it sounds like the vanes at the heater matrix that stop air going through the matrix (to make it hot) are stuck in the bypass position (to make it cold air) into the cabin and when you turn the dial to hot you are just bending the connecting rods which spring back into their original position when you let go, that seems like the diagnosis how ever I am not so sure how to get to the problem to fix it
