I own a renault kangoo 1.5 that is 4 years old, the ignition light keep coming on when the engine is on, (it shouldn´t be) and it seems to slow the engine down when driving, sometimes it goes off, I have been 3 times to the renault service, and is still not coming off. Can anyone give a solution about this problem ? thanks.
Let's be carefull out there
welcome to the forum. It sounds like the engine management light coming on and the car going into limp mode to prevent engine damage. There should be a fault code logged in the ECU although they are sometimes only detected when the fault is present. A good auto electrician should be able to read the codes and give you an idea of the problem
