1 - 10 of 10 Posts
Running a Kangoo Trekka 1.9 turbo diesel. I have a Russeck Pocket Mechanic handbook. My fuel filter is exactly as described and pictured in the book. However, it says that the filter can opened and the internal filter changed. On mine (without removing from the vehicle) it appears as if the unit is sealed and disposable. There are no apparent screws or anything. Does anyone have this type and are they replaced as a unit?
French Chemist:confused:
Hello, I have an 03 Trekka 1.9 Diesel 4x4. The fuel filter is a sealed unit and it comes with all the outlets for the pipes. The part number is R82 00 416 946 002201. £31.03 retail plus Vat. You cannot get into this sealed unit, Thanks Adrian
My guess,(and stress it's only a guess!) is that as with many 'utility' vehicle manufacturers (eg Land-Rover) they've eliminated the replaceable filter for a sealed unit. More expensive of course, but the 'plus' side is that it's less messy to change, and (as I did once with my old 'Landy')if the gasket on the unit has worn a bit thin, as soon as you turn on oil pees out all over your garage floor!
Hi i have a kangoo 4x4 and want to change the rear diff unit is it possible to get out without removeing the driveshafts from the hubs
Hello French Chemist,
Off topic if I may, I have a Kangoo 1.9 D55 van and would like to fit wider steel wheels to it. I don't yet know what width my standard wheels are but the tyres are 165/70x13.
Do you know if your Trekka wheels might be wider than this?
Many thanks,
Kangoo Hippy.....
I`m a trekka owner and whats fitted to mine are
185/65R15 Don`t quote me on this but I believe
theres about a 5cm suspension differents to get them to fit
Cheers
Pete
Cheers
Pete
Thanks Pete.
My Kangoo is having a starter motor fitted tomorrow so I will check that while I'm at the garage. I will be mobile this weekend!
Much appreciated for you help.
Kangoo Hippy.....
1 - 10 of 10 Posts
