Re: laguna 1.9 dci
HI,
I had the same problem with mine when i chnaged the engine, All me and my brother did was attach a bit of pipe to the bleed opening, and then with one of you pressing the pedal down the other sucks on the pipe, this gets the fluid moving and you get a pedel, need to do this a few times as it was ok then would loose pressure, once it sorted had no issues with it since.
Before people say this is not the best way to do it, this was needed as needed to get the car back on the road ASAP, and after reading you can get these kits to pull the fluid through , all we did was the same but the old way of doing it.
Hope this helps.
