Can any one help.
I just changed my rear discs and pads on my laguna.
During the replacement I had to change the NS caliper as it would not wind back in even with a bit of hammer
The problem I have now is even after bleeding the brakes on several ocasions the pedal goes nearly too the floor. The brakes work but pull to the right slightly and you have to press hard to get anything.
Could I have damaged the master cylinder seals by hitting the old caliper piston ?
Before I started the job the brakes were very good. ( whish I had not started it now )
Thanks in advance from a newbie.
Can any one help.
