1 - 13 of 13 Posts
hello i am new to the forum and have been searching on info on how to set up the built in bluetooth on my laguna to work with my mobile.does anyone know how to make the bluetooth visable to my phone.any help would be great.cheers...........:confused:
Hello & Welcome to the Forums Stid.
I'm not sure about this one, Someone should be along shortly tho who be able to assist with your post.
Ottoman
Hi, I would have thought that if it is working, you should be able to add it as another device and pair it with your phone
i am looking for how to switch the bluetooth visability on so i can pair it to my mobile.
hi there, dont think you will have built in from factory system as from what im aware this wasnt brought out till the lag 11 phase 2 from 2005 which had the headsup 3d sat nav system,
so you probably have a system that the dealership had put in? in 2002 you should find itl be a nokia system? can you see a nokia button around by the inst panel or centre console! when you start the car can you hear a beep? the nokia button should also glow blue when ign on!
let me know what you find goodluck bigshow
hi, ok, where did you read this aeticle? it is reffering to the lag11 phase2 version!
if your after a bluetooth the parrots the one ive lost count how many ive fitted now and not had any trouble apart from bmwx5 i did!
S
Is there still a deal on at Halfords for the Parrot system? IIRC they were selling them with free fitting a couple of weeks ago...
1 - 13 of 13 Posts
