Renault Laguna II - Phase 1 - Electronics - Front washer not working - member feedback req'd
I have a 2001 Laguna 1.9dci. When I activate the front windscreen washer the back one works instead? I have checked for blockages in the tubes but they seem fine. When I try the rear jet, that one works perfectly.
Can someone help?
Pete Naylor
My old style Lag did the same thing and it turned out to be the washer pump motor was knackered.
One pump did the front and rear washers ..... strange :crazy:
Apparently it rotates in the opposite direction depending on which jet you're using.
Hope this helps.
A Silly Question
Hi.. I've got the same problem with mine but can't see where the washer pump is exactly. Which covers do I have to take off to access it? It's near the screen wash bottle I'm sure but can't see exactly where.
Any help will be greatfully received as it's my MOT next week.
Thanks in advance,
Colin
