hi, we have just bought the car and we you start it up there is a rattle noise from underneeth somewhere
it sounds like a tin can rattling
can someone help us thanks steve60
hi, thanks for all your advice will get my local garage to have a look as am a disabled driver so cannot get under car myself thanks anyway steve60
I had the same problem with my Laguna when I first bought it, thought the exhaust was comming loose and hitting the car some where. Turn out a few of the fixings on the heatshield had snapped, think it was due to the car being jacked in the wrong place as the fixings looked torn and the rest of the heat sheild was bent out of place. A bit of bending and a few cable ties later and the thing is solid as a rock again. If you can't bend down there I'm sure a helpful friend or relative can get under there to do it for you. Saves paying a mechanic a fortune for a simle fix.
If the rattling occurs whilst the car is being revved, it could also signify the catalyst starting to break up. But I would check out the heat shield first.
Paul:)
