I wonder if someone can offer some advice... I posted on here before but was unable to get a resolution.
I've got a 2005 2.5 Renault master that will not start... left it standing for 2 weeks as I was not using it, came back to it and it would not start...
I can get it to sort of run if I pump the hand primer.. otherwise nothing.
Today I tried to check the pressure regulator on the high pressure pump and found that as soon as the ignition is switched on the regulator is vibrating continually... is this normal behaviour?
There is no low pressure pump to this van btw...
