I have an imported Renault Master 2006 automatic 2.5DCI (its a campervan manufactured in Germany)
Its service history has been lost and so i dont know if/when it needs a cam belt change.
I called Renault UK as they dont know if the model has a belt or a chain as the information they have is limited on the vehicle.
Is there any way i can find out if it has a belt or chain without taking it to a garage?
If the timing (chain/belt) cover is metal it's chain driven, and if its plastic it's got a belt..
Be on the left side of the engine where the auxiliary belts are. Problem hidden from view by the engine mount on your image.
51 plate Laguna 2 1.6
Under the casting with the "X" ribs on it. You may be able to tap it with a screwdriver and tell what the material is.
