Hello
Can the clutch master cylinder be serviced or changed on the robotic gearbox unit. I have the fluid drop fairly quickly (10 miles or so). No external leaks and the slave cyclinder was changed a year ago. When there is fluid the system works ok. Any help would be good. I do not want to change the robotic unit for this problem if possible.
Regards Kevin
Discussion Starter #2
I have found a master cylinder service kit part number 309300676R available from renaultgenuineparts.com for £120. I took the robotic unit off the gearbox to carry out the repair but possible to do in place after moving hoses and harness out of the way. Having said that more satisfying on the bench changing the parts.
