2019 Renault Traffic with Media Nav evolution I think it’s called. Looking for help identifying wire colours for right and left speakers, already had door cards off and found the 2 colours on each speaker is green and grey, both doors. Rear of head unit there is (on the connector that when pulled out the audio stops) only 1 green and 1 grey, makes me think they’re is another box somewhere in the dash that then splits this output to left and right door.
Any help would be much appreciated, as you can see my van is now in bits and would like to finish up the wiring.
Take a look at this and you will find the corespondence:
  • Like
Reactions: Abarth_1200
Thank you, going off that diagram are my speaker outputs on the same block with power wires? As the left most connector has too many pins. (Right hand block)
The audio connector is the one next to GPS & radio antennas.
The colours doesn't matter too much.
Check the postions of pins and find out for what it is.
Trimis de pe al meu SM-A705FN folosind Tapatalk
  • Like
Great that makes more sense thank you, I wonder if the reason I have a rear speaker wire present is because of the sat nav voice. I will use the pin locations instead of wire colours instead.
