Does anyone know if there is a sepparate fuse to control the cooling radiator fan, my daughters car has just overheated and it looks like the fan is not switching on.
any help
Thanks.
Let's be carefull out there
I have a seperate fuse in my Clio, it's located in the secondary box in the engine bay. To test the fan, disconnect the plug from the sensor on the radiator and bridge across the plug with a piece of wire, the fan should come on. If not it's either the fan or the fuse. If it does it is the sensor at fault.
