I purchased a renault Megan auto and recently the rear drivers window won't open.I have the option to use the drivers button to open and the passenger button to open but there is nothing there.
All the other windows work fine
any advise what this could be.
It's still under 3 months warrenty I just don't want to be mugged off
Contact Renault as their is a definite problem with windows mechanism , as I am having the same problem. They do have a cheaper rate to have the problem fixed for older cars , but if yours is still in warranty their should be no charge... . It is something to do with rain water being able to get into electrics. Hope you come right.
Ta Jane
If its under warranty take it back to the dealership they should fix it. Water gets into the window regulator and causes the window to stop working. I had to fix mine but I would definitely take it to the dealer if under warranty.
