1 - 10 of 10 Posts
G
Re: electrics
problems..lots..no wipers working..no indecaters working..no hazards working.. are they linked...??? ie one fuse or relay..please help..
Trev
megan 1 1997:(
Not sure about your car but on later Renaults the UCH (put your mouse pointer over it for a description) controls a lot of these functions
Diamond dismember
Re: electrics
Depends on what model and year your car is, but generally, hazards and indicators would be linked, but the wipers would be on a separate circuit.
The chances of either of these being down to just blown fuses, or something worse, also vary with model.
There should be an overview of what fuses are for which features in the manual of your car, and perhaps one inside the fuse panel cover too.
And if you edit your profile, add details of your car to the "in my garage" field, so you don't have to repeat it at every post. :)
Re: electrics
Look under the drivers side of the dashboard,the UCH is under there.Check for signs of water ingress,especially if the car has a sunroof.
1 - 10 of 10 Posts
