Hello everyone!
I could not find a right solution/topic in this forum, so I ask my question:
The car's clutch "release bearing" was out of position... I pressed the clutch and the start button, but the switch was in a gear1. The car start and stop... Then the car does not respond to starting (I can hear a small click and later once again.)
No electrical functions have been working since then, except the hazard warning flasher and opening the door with card.
Any idea/solution?
Thank you!
Discussion Starter #2
Hello everyone!
Any idea/solution?
Thank you!
Maybe, this is the same problem?
possible, but we have no idea of what car you have
OOPS my bad, Never look at the title ( My excuse and sticking with it )
what year?
Black under bonnet fuse box or black and white
But check the fuses first on the battery positive terminal
You will need a multi meter to test them ( 3 of them ) dont look like fuses, but they are ( In side that Red Box )
