Hey guys, Ive just discovered these forums and hope you can help. Ive just bought my first car, a 2nd hand P reg (1996) 1.4 megane.
Im a bit confused about the headlight operation. On my left hand stick I can turn it once to put on the sidelights and if i turn it again, it puts it on headlights. Thing is, I dont know how to switch between dipped lights and full beam lights. Both icons for dipped and full beam are on the same notch. the inner switch has an icon for fog lights i think but this dont do anything. I can flick the fog lights on by pulling the stick towards me.
Im I doing something wrong or does it sound like the switch is broken? Hope this made sense! Please help!
It is usually the other direction from the "flashing". So if you pull the stalk towards you to flash your headlights, try pushing the stalk away from you. This is generic info by the way not specific to the P reg Megane. So I hope it still works for you.
The fogs should only work when you have dipped beam switched on and won't work with just side-lamps on or when you have main beam. This is generic info too.
Good luck and welcome to Renault Forums by the way.
Vass20
Let's be carefull out there
welcome to the forum. With my M reg Clio, turn the stalk 1 click for parking lights & 2 for dipped / head lights, to switch between full and dipped pull the lever back and it clicks and heads are on, pull back again to turn back to dipped. To flash I have to pull twice otherwise I'm left on full.
