Hi I'm a QUalified HGV Technician, but you'll know as well as me Cars are completely different to trucks
I have a Renault Modus 1.4 petrol which had a missfire on cyl 1 obd dtc p0301. I have replaced all the spark plugs as matter of course although they looked good.i also swapped the coil pack from number 1 cyl with number 4 cylinder rechecked the obd and the code changed to p0304 cyl number 4 miss fire. so I went on to buy a new coil pack. fitted the coil pack and it still shows the fault on number 4. i swapped the new coil pack with number 1 and it still shows the fault on number 4. however the rrignal fault was on number 1. if i delete the dtc it runs fine on idle but as soon as you rev the engine it comes back on any ideas
