I have just fitted a new clutch in my Renault modus 1.4cc before it was taken apart the car started up and drove now it's all back together with a new clutch fitted the car won't turn over it's like there is no power getting to the starter motor. The immobiliser light flashes when the key isn't in the ignition when you but the key in to start the car the immobiliser light stays on
Any help would be appreciated thanks in advance Wayne
Go back over everything you disconnected or worked close to.
I suspect a cable not connected.
Discussion Starter · #4 ·
Checked all wires and cables and double checked all the plugs going to the gearbox and engine removed all the earth cables cleaned them up and put them back
You have checked battery voltage?
Discussion Starter · #6 ·
Done all of that had the aa out and they are saying the immobiliser is locked on but the immobiliser light doesn't flash when you go to start
