Hi the rear window of my Renault Modus exploded tonight - I dodn't see any rogue snowballers and there was no debris in the road that could have hit it - could having the demister on in the cold weather (or just the cold) have caused it? If I get it replaced (which could take a while - thanks Autoglass) is it likely to happen again?
Hi there.
I've moved your thread to a more relevant section, whereby fellow owners can advise of their experiences.
Paul
My first Modus did exactly the same. The electric rear window is supposed to switch itself off when it gets hot or has been on for long enough. If you see it has switched off and switch it on again - POP!
