Hi All,
Bought some new front pads and opened box there was 2 bolts in sealed box, but 4 are loosened it total when removing the calipers. The same amount appeared from a wrong set from G & S & French
Any ideas why ??
Any help gratefully received.
Glyn
You don't have to remove all four bolts......
If you undo the bottom ones,the caliper can be pulled up with the top bolt still in place.:)
