I recently brought a 1.6 1998 Renault scenic its done 60,000 miles.I was driving it the other day and there was no hot air coming from the vents,then i noticed the temp gauge going up eventually it overheated with steam coming from the under bonnet.I checked the water level and there was none in there i unscrewed the cap slightly to let the pressure off and some water bubbled up back into the bottle.I put more water in and it was fine and the heaters worked ok again but now the temp is starting to creep back up, i cant see any water leaks underneath so im wondering if it could be a faulty radiator?
Any help would be great
thank you
thank you
