I have a 2005 Scenic 1.9 dCI which runs OK, but the service light is on nearly all the times, with the mesage "Check Emission".
I have looked at the OBD system and found this error message:
Code: PO487
ECU: $7A Lightning
Description: Exhaust Gas Recirculation Throttle Position Control Unit
The engine is equipped with a ECR heat exchanger type. When taking of the solonoide the valve works quite OK
Do anyone have an idea of what is wrong?
Kinde regards osc
Code: PO487
ECU: $7A Lightning
Kinde regards osc
