1 - 9 of 9 Posts
I presume do you think noise stops when I press brake pedal. How / where to get it fixed kwik fit or dealership. Is it dangerous to drive it there or could I damage the car?
Any advice much appreciated.
I'm sure this has been discussed on the forum before,so it may be a common fault....
I certaintly wouldn't bother with Kwik Fit!.I'd try and find a good local independant or Renault specialist to have a look at it.:)
i have this problem too and the hissing is getting worse...would this fail an m.o.t....cause my car was m.o.t'd 2 weeks ago and with this problem....anyone know what sorta money is involved in replacing it??
As long as the servo and the brakes worked as they should at the time of the test then there would be no reason to fail the car.
I'll try and find the other thread that discussed this problem and post a link.:)
1 - 9 of 9 Posts
