41 - 60 of 94 Posts
Ian been asleep since you had disc, what number is it?
Found it
Ian 1 touch driver window switch ( Press and window goes down )
Or you have to hold switch for window to go down?
You Tart. LOL
So how do we Know what wiring diagram then
AS this disc is showing 3 types
DRIVER'S ONE-TOUCH ELECTRIC WINDOW + ANTI-PINCH + PASSENGER ELECTRIC WINDOW
FRONT ELECTRIC WINDOW ( Not this as back are electric )
Discussion Starter · #45 ·
Oh OK. I though you where thinking I do not know how to open windows. Wow OK. Harder than I thought .
I went into R2. - Then wire Diagrams. - Then Rear electric windows - Then DD/VARIP
LOL
Ok But haven;t you played with the R2 connector
DIalogys does not really cover electric windows as such.
So when I fill Oval plate in, it does not show what type of switch fitted
AND I cannot remember how you tell the difference by looking now ..
You have not changed switches trying to solve this, as they look the same but are different inside ( Bad egg you living in a scrapyard for your parts )
Replace the switch back with correct 1, they are different inside, unless numbers match exactly
Discussion Starter · #49 ·
I have replace it straight after I tried to see if it's the switch. It had the same response on both switches. I can also not open windows from each window
Is the White Fuse box on a 1.6 the same as on the 2.0lt
Yes Ian, have you the white fusebox then ( Green line in the Wiring diagrams )
Or did you work this out
Discussion Starter · #51 ·
Sorry I missed you here. ( Green line is the wire diagram ) Huh
Could it be a fusebox issue as the auto Electriction did not know what he was doing. Can you blow the fuse box ?
Oh yes you can blow these as easy as .
ARE you sure you have R2 wiring correct Just asking
You know where each wire starts, and each wire finishes, so R2 plug is not really part of the equation.
a long wire, use this with Ohms meter, connect to the furthest end of wire,you are checking and then get at The beginning and connect Ohms meter, to both wires, your original circuit, and your bridging circuit, this saves any messing as to if wires are correct in R2 plug
Discussion Starter · #53 ·
I am not sure I think so. I checked wire from Drivers switch to after R3 connection. Marked them as to position on drivers plug. Then went to Diagram and follow to R2 connector. Got number and checked it correct on R2 connection. Had a few out. I then followed wire from R2 to left door plug R13. All wires when into plug.
Other wires went into 1029
Were the windows working before you messed with R2 plug, this is what you have to ask yourself
Discussion Starter · #57 ·
I do not know. As I brought the car with windows and hand brake not working. The difference is that the hand brake did not work and does now and Drivers window worked and does not now. All other windows did not work. Car sat for 3 years at auto Electriction. As guy that started job left with out finishing the job. Next guy did not know what was done or were to continue from. I checked the Window mechanism and The thing I think is the solinod. That attaches to the window motor had been taken out. All 3 of them. I replaced them from scrap yard. Only one that was left was drivers door. I do not know for sure if this 3 solinod are working or not. I hope They are.
Is there anyway to check if they work?
Same all around, so move it around and see if windows now work
These temics fail at an alarming rate
I have a box full of the beggars
41 - 60 of 94 Posts
