Thanks I will try tomorrow. Thanks mate. Have a great night.Same all around, so move it around and see if windows now work
These temics fail at an alarming rate
I have a box full of the beggars
Hi allClick on Code 131 rear window,
Click on wiring Icon, then click on drop down box only two variants , Click DD
Should now see your diagram
Click Download save
Simples
work backwards from your temic
You only need 1 working Temic, THEY are all the same for your car so if 1 works on 1 window, but not on another window, then its not the temic
Thanks alot I found it. It all good. Started checking every wire and conections again. I put a new second hand plug on, so busy reconecting it and just connecting it straight wire to wire .645 = UCH
assuming the other numbers must be for windows
Didn't Dial open up in the correct place for you,
And tell you what disc to use
Ok code 203 , click
Click wiring icon,
Click the type of car from drop down
Bottom diagram, Anti pinch , you will find 21K there ( Its the wire going from the switch to the UCH)
See the other number at the opposite end
DONT go on this number as just used a drop down section and went epack
Should still begin with a C
That number relates to a wire going to 1 of the plugs on the UCH
so now flick over to Fuses, scroll down to UCH , AND find this wire,
You know what its called, Now see what plug it goes in, and you should then be able to check for continuity
PS I have used NT8388
That is a plain lieHis Machanic says the gearbox must be set
HI LVR thanks so much for your reply. I not going to risk it. ThanksJust my opinion:
Of all the stupid designs ito allowing proper faultfinding for intelligent servicing of an auto box, the DP0 auto must surely take the dunce award - its absolutely pathetic.
There is but a single measurable parameter on the box, and that is with a lot of faff involved - the regulated pressure that basically governs all proper mechanical operations on the box. - most all other auto boxes have external ports where a pressure gauge can be screwed into in order to see/confirm the correct operation of the electronics in combination with the mechanicals in the box ........................... not so on the DP0 - there are NONE.
So I would say if you have a reliable Renault speaking scanner on the thing while driving both HOT and ice COLD (this is very important) and you see any moans about pressure regulation issues on the box or strange/abnormal (even slight) behaviors, rather skip the sale - especially in combination with the 2.0 engine.
Everybody and his dog will always want to tell you a DP0 is easy to sort by replacing the solenoids and its simply not true - its a pure expensive guessing game.
That is a plain lie
Hi all. OK so the progress on the window not working. I checked again and redone the wires from R2.645 = UCH
Ok code 203 , click
Click wiring icon,
You got me I do not understandTake drivers door switch out, and close the pins inside the wiring plug that goes to the switch
What about the wires that I am talking aboutYou got me I do not understand
OK but what about these two wires from white plugYep those plugs
I am using the Diagram program that you sent me NT8388what Visu are you using
