What about Dialogys
Did you save the report
If yes
send it me
I did not save it.What about Dialogys
If yes
send it me
This is a copy past from the other dayI did not save it.
It was one code in UCH
To day I put the Can clip on and the UCH had a fault code in yellow DF031 ONE TOUCH WINDOW CONNECTION
I erased this code and then Driver window opened and closed, Back right window went down on both up and down command.
This is the code.
Where would I find it in Diaglies
What about Dialogys
If yes
send it me
Thanks I will try that tomorrow. Thanks StuartCheck emails cannot really reply here
I am under same rules as members on the forum
And dont want banning
I have sent you an emailThanks I will try that tomorrow. Thanks Stuart
Cannot make any of that out
Did you manage to get the instructions ok.
And get everything work together .
Yes I did ThanksCannot make any of that out
Rear window. Turn the silver part of the motor 180 degrees
This will sort that
Reply
Juddery window.
Whats it doing going down in 5cm increments
Stupid system on these
Did Dial show correct visu number to use or are you sticking with 1 I sent you
Juddery window no about 1cm
I am using the DD with the one with ONE TOUCH WINDOW CONNECTION
