This is my first post, so please be nice :)
I've got an 04 Scenic 2 DCi 1.5 that I've had for about 3 months. Everything worked fine until about 2-3 weeks ago when one of the connectors on the drivers side wiper arm came apart. This is the bit where it joins the link arm right at the end of the arm.
The arms will push back into place but there is nothing to fasten them together and the wiper arm drop out of the bottom of the bit where it fits into. A metal rod comes down, about 8mm in diameter that fits through the hole in the arm, but its smooth, so no obvious way of putting a nut on it to stop it coming apart.
Apologies for the lack of technical language - normally cars only come in different colours, but I want to learn and try to avoid paying out £100s for something that seems like a really easy fix!
Dave
