Hello forum.
I have posted on this forum under "electrical fault maybe" the problem with my Scenic auto. I have just rang Renault and their service guy says he almost 100% convinced that it is an EMV Valve. What is this and is it a major job? He is quoting £74.99 to look at it and if it is that around £350 to fix it. Does that sound right? I know jack about cars except how to point and drive. Any help would be gratefully received.
Chris
Its strange you should mention that as I lifted the bonnet when I got home and the fan was going and a lot of heat was coming off the engine.
I have tried looking for the ATF dipstick but cannot find it? any suggestions?
Chris
Let's be carefull out there
The newer autos dont have an ATF dipstick although there may be a plug at the front of the box about half way up. The fluid should fill to the level of the plug, renault have a special tool for checking it though. On my Clio there is an oil cooler and when I had a block in the cooling system I was getting problems with the auto, one of the things I cleaned out was the oil cooler when I flushed the system.
Thank you Chris. So does that mean I cannot, or supposed not to check the level? Thats odd isnt it.
