1 - 8 of 8 Posts
My new scenic beeps 3 times when I start it. This has only started to happen in the last couple of days. There are no warning lights, and no warning messages on the display.
S
Have you consulted the handbook? It could be a number of things including a fuel warning, seatbelt warning etc. etc.
Happen to mine . You need to reflash the firmware . That's what they did to mine. Not sure how it came to be corrupted though
Problem solved, Thanks
Thank you all
I solve my problem. One of the back door had been blocked ( cause of child pull the handl when i unlock back doors and windows). When i fix it (lock and unlock again than child lock) tha back door unblocked and the beep is stope.
I don't find any information on the manual.
I had exactly the same problem and the childlock on the door was kinda jammed. Once it worked properly, the beeps went away. Thanks for your help!
New to this sire but very grateful. I had the same problem and somewhere in the thread it was suggested to turn the ignition on and press the childlock button three times.
IT worked - problem solved. Thanks for your help
1 - 8 of 8 Posts
