i was going to top up the 'scoosher' tonight when i discover i cannot open the bonnet from either the clip at the front of the bonnet or using the mechanism just under the dash. any thoughts? expensive to repair? can i sort this myself?
cheers
Discussion Starter #2
hello, i cannot get my bonnet to open. the switch under the steering wheel seems 'dead'. 2002 scenic expression. any thought? how much to repair?
cheers
Sorry you haven't had a reply.
It sounds like the bonnet pull cable has either broken or come unclipped,and this is usually a nightmare of a job on most modern cars.You need to get to the bonnet catch and try and open it,but it's usually well hidden and some have security panels over them to stop people from breaking into the bonnet area.
Hopefully someone with some experience of doing this on your car can offer some more specific advise.:)
try ger someone to pull the lever holding it in open postion and yourself bang on the ffront of the bonnet should relese you might find latch needs greasing hth
